Assuming the SRS is related to the rack replacement, most likely they severed the spiral cable because the tech didn't bother securing the steering wheel before installing the new rack and allowed the steering column to rotate too far and damaged the spiral cable. Is your horn inoperative too? I can confirm from actual experience, access to the Z32 manual is still available in ASIST in the dealership if we're talking about Nissan dealers, and how to pull codes and perform diagnosis for this concern. I see you're in Dallas too! Also I have ConZult and can pull your airbag codes if you'd like.
